dtzackus's avatar
dtzackus
Propane / CO2 Detectors
Ever since we had our new rig, our propane/CO2 detector has always given us an issue. Nothing like waking up at 4am with the alarm going off. I am not a big fan of leaving the gas on while we sleep unless we need heat during the night.
Heck, I heard the alarm go off while I was cutting grass next to the unit. I looked online last year and cleaned it with our sweeper in the unit, but didn't do anything. This time I unscrewed the alarm and disconnected and put two wire nuts in it's place.
The two other alarms are both battery operated, can I purchase a battery operated propane/CO2 detector, or do I need to purchase a replacement alarm?
Thanks in advance...
  • dtzackus wrote:
    Our rig is a 2012, I hope they last longer than 3 years....
    I agree with you, hopefully they last longer than three years. Since you pulled it try looking at the back and see if there is an expiration date. Also you might try to figure out if the CO or the LP alarm is going off.
    Since both alarms need LP to sound you could turn off the gas at the bottles and then light a stove burner and let it burn out. Now turn on the gas only and let it sit that way for the night. If the alarm goes off you know you most likely have a propane leak.
    Also when you say it goes off at 4am it makes me think your batteries are draining and setting it off. You might want to find a way to check battery voltage in the middle of the night if the alarm sounds.
  • A dog farting near the detector will also set it off, so if Rover likes to sleep on the floor near the detector, that could be a culprit. I would never sleep in the unit without a detector for gas though, as waking at 4 am is preferable to never waking again.
    JM2C
  • I have a similar problem with a battery powered smoke detector. We have to pull the battery while cooking.
    I suppose I will have to replace it or maybe move it farther from the kitchen area.
  • Do you disconnect the battery when you have the trailer parked in storage??
  • Kidde makes a CO detector with s ten year lithium ion battery. About $50 at Home Depot
  • Our rig is a 2012, I hope they last longer than 3 years....
  • Low DC voltage
    Defective Unit
    Expired Unit..they have a shelf life. Expiration date is usually stamped on backside
    Replace it........be safe!
  • I would never use a TT without a working propane/CO alarm. Propane is heavier than air so it needs to be close to the floor. CO is about the same weight as air. It's odorless, aka "the silent killer". You might want to add an extra CO only detector near head hight.
