nike_holleyExplorerJun 14, 2016Propane...We have dual propane tanks on the tongue, under a plastic cover... What's the easy way to check levels & not run out of propane..??.. Thanks... Nate
time2rollNomadJun 15, 2016Do you have an automatic regulator with the green/red indicator?If so wait for the red. There will be a pointer indicating the empty tank.Move the pointer to the other tank and refill the empty.If you do not have such a regulator... get one.
Related ContentPropane Refillsmy propane generator won't startPropane!Doing without propaneSmaller Propane Tanks
