CharlesinGA
Jun 30, 2021Explorer
Is this 12v powered? if so do you have a volt meter? Its possible the voltage is dropping off, as I think they will activate with low voltage. Sort of a warning that they don't sense properly and are failing due to the low voltage.
Are you plugged into a pedestal at a campground? If so check the output voltage of your converter.
Charles
Charles
