foxyfades wrote:
I have recently purchased first trailer and is bit of a fixer upper so I am fairly new to this. I have been trying out everything to see what works and does not work. I tried turning on my furnace, water heater, and stove with no success. Tanks about half full. I have tried switching tanks and switching lines but I can hear the gas filling line. When I removed line from the regulator to trailer you could smell the gas leak out so it seemed trapped. I attempted to blow out the lines with compressed air and debris shot back out, did not clear the line. Has anyone run into this or know someone who has? I would really appreciate any help. Thanks in advance.
When you try to light the stove with a match is there any pressure blowing either gas or air in the line? This will tell you if you have pressure to purge and light the burner.
