foxyfades wrote:
I have recently purchased first trailer and is bit of a fixer upper so I am fairly new to this. I have been trying out everything to see what works and does not work. I tried turning on my furnace, water heater, and stove with no success. Tanks about half full. I have tried switching tanks and switching lines but I can hear the gas filling line. When I removed line from the regulator to trailer you could smell the gas leak out so it seemed trapped. I attempted to blow out the lines with compressed air and debris shot back out, did not clear the line. Has anyone run into this or know someone who has? I would really appreciate any help. Thanks in advance.
Just a long shot but when you open up your tank valves, just turn it a couple of turns, don't open the valve all the way open. Then go to your stove and light it up, leave the ignitor on the pilot orofice until the stove burner comes on. Then go out to your propane tank and open the valve all the way open
