Heheh, yah, I went through this without major connections.
I have an Low Pressure, quick connect just under the back bumper on camper.
The catch is, it's a low pressure (LP) connection. Most BBQs have the pressure valve on the BBQ hose too, so now you have a LP going into another LP connection and the flame is minimal at best.
Trying to find a direct hose, without the bbq LP was hard to find..
I couldn't find one.
So the only options I saw was to modify adaptors/connections with fittings which became a "Frankenstein LP Connection"..
So the LP hose on the camper, is pretty much worthless to me.
I've seen some that have adapted it, but?? way overboard for what it should be. I"m guessing there are LP BBQ but nothing that I saw worthwhile.
And finally, there are "Adaptors" that can be screwed on or off as needed, the key is the LP from the camper hose to the BBQ hose with the Temp control on it..
I'll be interested in what solutions popup here, thanks..
