tshirtman wrote:
Not sure if the propane is running the fridge. Have the fridge set on gas and the propane is on and works on other appliances.
Please let me know if th3er is a way to test?
Use this method when in tow to keep the bev's cold(beer AHHHHH)
thanks to all!!!
You don't mention make or model of refrigerator, but these days they typically have a slide switch marked gas or "auto". If you have it on "gas" then yes, it's operating on propane (the fridge does require 12v power for the controls, so if your house battery is charged or you're drawing power from the TV through the wiring harness, it's all good). If the fridge is in "auto" mode, it will run on propane if you're not plugged in to 110v AC current; if you are then the heater necessary to operate the cooling system will be running on electricity.
