jimh406
Sep 06, 2020Explorer III
I’m not sure why it would take you hours and hours to get your generator back going or why you need to run your generator during the Winter an hour each month. What was wrong, or what did you do to fix it?
You should be able to prime the generator and as long the battery is good, you shouldn’t have an issue getting it back running. One other hint to to ensure the propane lines are full by running other items like the stove.
I’ve had the case that the propane fuel had either water or too much additive in it. That caused my generator to sputter.
