noteven
Sep 10, 2020Explorer III
Slymer - Compression, fuel & air in roughly the correct ratio, spark, and sufficient cranking speed and the engine will start.
Propane mixture in cylinder has a higher resistance to ignition than liquid droplet fuel (gasoline) One thing to check is the plug gap is in spec for propane. This is more of an issue under heavy load.
I still suspect fuel starvation.... if you give the engine a little whiff of starting fluid does it fire and try to run?
