time2roll
Sep 25, 2020Nomad
Slymer wrote:This does not sound like winter maintenance issues as much as you need to get the generator running correctly.
I have tried quick start fluid, with no luck, but this is not an engine. It is a built-in propane generator. Definitely getting spark and all other appliances are getting propane but it appears the generator is not. I have managed to get a couple of hoses off & blow them out. Still no luck. Just cranks over & over.
Got it running about a month ago, finally,.....but now again no luck.
If you have checked the basics.... might be time to get service. If you start every 6 days or 6 months it should start fairly easy.
