naturist
Jul 31, 2015Nomad II
That is a propane quick connect fitting. This is NOT the same as a compressed air quick connect fitting. Be alert that, into the bargain, TT makers have used two different incompatible quick connect systems, which, along with the compressed air one all look identical. They are just enough different that you cannot connect one to either of the others.
I have done exactly what you want to do, i.e., connect a standard BBQ grill to that connector, and to do it, you will have to remove the regulator on the grill, as the propane line connected to that fitting is a low pressure line. You need the appropriate propane hose, the right QC (male) connector, and such plumbing as needed to tie into the grill.
44,072 PostsLatest Activity: Aug 30, 2026
