There are 1 versions of the TYPE I ACME Nut
Older Version the 'thermal bushing' is fully visible
THEY Leak
Newer Version the 'thermal bushing' is not as visible
They are much less prone to leaking
ACME Nuts are designed to be 'hand-tightened' to fully seal
They have to be tight enough to open the spring loaded chutoff vlave inside the OPD Service Valve opening
Stub inside ACME Nut pushing the valve open when properly tightened
When attached to OPD there should not be any leakage from the ACME Nut
If is does....try to hand tighten more
But shouldn't be that hard
