Emily_Eisenman wrote:
Unfortunately there is no port or connection under the trailer.
Maybe look closer. There might be a capped tee in the black pipe if lucky, but were quick-connects common back in '92?. We had a tee on a previous TT. Problem was, it was near the front of the TT but our entry door and kitchen was at the rear. I bought some long propane hose and tie-wrapped it to the black iron propane pipe and installed a quick-connect at the rear.
Where is the regulator? Can you install a tee on the low pressure side? Regulators are usually at the tanks these days and there's a single "bulkhead" fitting in the A-frame area that adapts hose to iron pipe. Perhaps if you have a bulkhead fitting you could add a tee there?
When it comes to propane, there's all sorts of various fittings & sizes and with flare or pipe thread connections. I've found that Ace hardware has a good selection.
