hohenwald48's avatar
hohenwald48
Propane Regulator Cover
I had to change the auto changeover propane regulator. I used a different brand than the original. The old one had a white plastic cover snapped over it and it doesn't fit on the new regulator. I think that cover is just for looks and I don't really need it do I?
  • TucsonJim wrote:
    Not a problem at all. Your regulator should last you many years, with or without the cover in place.
    Yeah, the one that failed was on my 6 month old TT. However, the regulator didn't actually fail. One of the brass fittings that the pigtail connects to just broke off. I smelled propane, sprayed the fittings with soapy water and found the bubbles. I just barely touched the fitting with my bare hands and it broke off flush with the regulator housing. I was afraid to try to use an easy out or drill for fear of getting metal chips inside the regulator. $45 and I got a new one and back in business.
    If I get bored one day I may try to get the fitting remnant out.
    I don't have the large dual bottle cover shown above. I had to remove that when I installed a Stromberg-Carlson cargo rack to mount my Honda eu3000is generator.
  • Not a problem at all. Your regulator should last you many years, with or without the cover in place.
  • LP Reg cover is cosmetic---nice to have but not necessary
    Large screened vent should be pointed downwards so that rain/snow etc. doesn't get in.
    With a propane cylinder cover in place reg is protected anyway.
  • I wouldn't worry about it...especially if your tanks and regulator are inside a cover already.
  • I would make sure I had when if the regulator is exposed to the weather.
