Hornnumb2
Mar 04, 2015Explorer
propane regulator
When I went through PDI the guy said my regulator didn't automatically switch, I was thinking that all the new trailers would have one? Thanks
CavemanCharlie wrote:It's all about options and choices... Since most TTs now come with auto changeovers, than you have the OPTION of using it or not... Indeed, some may use it when it makes sense to them, and not use it when it makes sense to them.mtofell1 wrote:
Those of you not wanting auto-switch over why don't you just turn off the out of use tank? Problem solved.
I suppose that's true. But, if one tank is turned off then you still have to go turn the second tank on when the first tank runs out. So, what has been gained by the auto switch??? Might as well be a manual one.
