VTLeeExplorerJan 05, 2017Propane Regulators Freeze?It is 15 degrees and I tried to turn on my propane as I wanted to do some work on the inside of the camper and the propane will not work on either tank. Could the regulator be frozen?
jimh406Explorer IIIJan 05, 2017How are you determining the propane won't work? Are you sure you didn't leak out? Are you trying a burner or something else?
Related ContentPropane regulator?Propane regulatorPropane RegulationPropane Regulator IssuesPropane regulator making noise
