Baja_Man
Oct 25, 2022Explorer
MFL wrote:
Your factory installed propane alarm is designed to be very sensitive, if still functional. It should work better than your nose!
Often times an RV furnace, or oven will give off an odor, when new, or when not used for a lengthy time. This will go away with use. If only running for 5-10 minutes, it may smell again next time.
You can purchase a small propane gas detector, that will fit in hard to reach areas. They are not expensive, google will help you.
Jerry
Propane alarm is new last week. Ordered a small pencil type propane sniffer. I will run all appliances and heater a couple of more times and see if odor stops lingering around.
44,070 PostsLatest Activity: Aug 06, 2026
