Baja_Man
Oct 27, 2022Explorer
Vintage465 wrote:
I've had propane smell twice in my coach. Once it was the little supply tube that leads to the pilot for the oven. When you light the pilot it would leak just a fuzz amount where the compression nut tightens to the pilot. Why the pilot didn't burn it off is a bit of a mystery to me. The other was where the copper line tied into the furnace. It had a little fuzz leak and when you'd turn on the furnace and blast thru the duct system it would suck that fuzz leak smell throughout the coach. S'pose the bottom line is check all your connections that come into the coach. Stove/Oven. Referigerator. Furnace. Water heater, but if that is leaking it should vent to the outside, but I'd chech it all anyway.
I turned on propane yesterday morning and left ALL appliances off.
The propane alarm does not appear to have sounded/triggered.
After checking today, it looks like my oven is leaking. The smell appeared to be coming from around that area so that's where I started. I used a gas sniffer.
It appears to be leaking near line that enters oven. I'll see if I can find some product info/manual to see an exploded view and give me an idea of what I'm looking at. I'll start by removing the interior grate and lower shelf (screwed into sides). This will provide me access to burner and the pilot area.
44,071 PostsLatest Activity: Sep 17, 2026
