Baja_Man
Oct 29, 2022Explorer
I checked again today. The propane appears to be leaking from the line that comes from the oven pilot assembly (where control knob connects). Pic attached. I tightened it, but it did not stop the leak.
I believe there should be no propane leaking from the end of this line at any time, except when the oven knob is pushed which allows propane to flow through this line to the pilot. Is this correct?
I will now test to see when gas is turned on, is it leaking from this line when knob is NOT pushed. Sound correct?
NOTE: The line that enters the pilot burner assembly has a brass end piece (cap sleeve) with a pin hole on end. Is this to reduce the amount propane flow?
44,071 PostsLatest Activity: Sep 17, 2026
