opnspaces
Oct 31, 2022Navigator III
In your picture above you have the tip of the sniffer sitting on a round silver piece. Is that silver piece a bolt blocking off a hole? Or does the copper propane line in the picture thread into the end of the silver piece?
If it's a blocking bolt I would probably try removing the bolt and using some thread sealant on it.
If the copper propane line connects to it then it sounds like the control has a very small leak. In this case I would try using some fine emery paper on the sealing surface of the copper tube and freshen it up then screw it back in making sure it goes in straight.
44,071 PostsLatest Activity: Sep 17, 2026
