Baja_Man
Nov 01, 2022Explorer
opnspaces wrote:
In your picture above you have the tip of the sniffer sitting on a round silver piece. Is that silver piece a bolt blocking off a hole? Or does the copper propane line in the picture thread into the end of the silver piece?
If it's a blocking bolt I would probably try removing the bolt and using some thread sealant on it.
If the copper propane line connects to it then it sounds like the control has a very small leak. In this case I would try using some fine emery paper on the sealing surface of the copper tube and freshen it up then screw it back in making sure it goes in straight.
The silver fitting is not a blocking bolt; the brass line connects to the end of it. I cleaned the end fitting and ensured it went in straight. Still leaking.
Thermostat control is not available...parts have been discontinued since Atwood was purchased by Dometic. Tried several well-know outfits, and they all said the same thing...not available.
Found an entire new manifold assemble with the thermostat control I need....$150!! If I replace with this, and something else goes out, I'm back to square one.
Used part was found but I will not install a used part.
I decided to replace the stove. Found a 17" Greystone that should fit. has a one year warranty.
44,071 PostsLatest Activity: Sep 17, 2026
