RescueRam3's avatar
RescueRam3
Propane Tank in Way of WD Lift Brackets
I have a 2014 Keystone Bullet 308BHS and a Curt Weight Distribution Kit. When I go to place the lift chain attached the spring bars to the lift/snap-up brackets, the lift bracket is too far back. In other words, the chain does not go straight up from the spring bar to the lift bracket. The lift bracket is too far down the frame, resulting in the chain going up from the spring bar to the lift bracket in a pretty good angle. The fix would be to simply move the lift bracket closer to the hitch, BUT, the propane tanks/tray is in the way. I believe the propane tray is welded to the frame so that not so easy to move out of the way.
My stupid ass dealer give me a deer in headlights look and has no clue what to do, or at least seems disinterested in helping me fix the problem.
Solution?
