Caveman_Charlie
Oct 28, 2014Explorer II
Passin Thru wrote:
Bring it by and I'll tell it not to ping. I'm an Aircraft Mechanic, the pilot said, Plane lands crooked so I told it to straighten out and run right. Put some rubber gasket about 1/4 in thick under the tanks and that will muffle it.
Well,,,, I didn't get all of this. But, maybe if you put some padding under the tanks where they set, it may solve the problem. What ever in the tank that is making the noise it is probably being magnified by what they are setting on. It would be the easy thing to try !
