- HuntindogExplorerI can see where it would be handy. I often forget to check my tanks until it is cold, wet,and dark outside.
- Does it give the level or just empty? Ultrasonic sensor sounds great.
- AvaExplorerYou can just run a little warm water over the tank and you will see where a cold line and the level of fuel in it. More accurate than any gauge. Always an option anyways.
- Figured it did.. My TV remote tells me when the batteries are getting low too.. ;)
Glad it works and knowing the level of your propane is important. I pull the cover and check and that works too. :) - trail-explorerExplorer
MitchF150 wrote:
What if the batteries die? Hopefully, it has a sensor for that too?
When the batteries die, you replace them. There is a battery status monitor in the bluetooth app.
I ordered mine here and have had them a few weeks. LOVE IT! - Or, just lift the cover and check the auto switch gauge?? Ha, ha... ;)
Okay, that's a pretty cool thing with all the current tech and smart phones and all and that's great.
It's gotta use batteries thou, right? What if the batteries die? Hopefully, it has a sensor for that too?
Anyway, glad you are excited for it and I hope it works as you expect it to.
Mitch
44,064 PostsLatest Activity: Apr 12, 2026
