Bigbird65
Jun 15, 2014Explorer
Propane tank question.
I have two vertical 20# propane tanks. Is there a device that will tell me when the tanks need re-filling? I really don't want to empty them just to know that they need to be re-filled.
camperpaul wrote:bguy wrote:
Just leave one tank valve closed while you use the other tank. When your propane goes out, switch tanks. You now know you will always have 20lb propane in reserve. Now you go fill the empty tank.
That can work in the warmer months but if you are boondocking in Winter and the first tank runs out at two o'clock in the morning and you have to get up, get dressed, go outside into the blizzard to switch tanks it gets rather inconvenient.
