Bigbird65
Jun 15, 2014Explorer
Propane tank question.
I have two vertical 20# propane tanks. Is there a device that will tell me when the tanks need re-filling? I really don't want to empty them just to know that they need to be re-filled.
bguy wrote:
Just leave one tank valve closed while you use the other tank. When your propane goes out, switch tanks. You now know you will always have 20lb propane in reserve. Now you go fill the empty tank.
jaycocreek wrote:
Hot water poured on the tank shows you exactly how full it is with feel. I have two 25gal(100 lb) tanks I replace my 7gal(30#) tanks with for long stays.
I think I have as many propane tanks as I do generators.I really like my 10 gallon tank I use for the catalytic heater... With hot water guages are not necessary for my free standing tanks.
Majja13 wrote:
I am in the only use one tank until it is empty and then manually switch to the other.
