Tarkin75 wrote:
Reddog1 wrote:
When the lady at Suburban Propane even quoted the regulation you're quoting and said there are some exclusions, did she say what they were? I mean no disrespect to the person who does this for a living, but it would not be the first time they were incorrect.
I went through this with the last TC I had. The real problem is when and if you get the problem solved locally, you may not be able to get them filled on the road.
Wayne
I have a feeling it's more of a CYA type of scenario where it's easier to have the guys who do the work check it out and estimate what is needed. And i'm ok with that... doesn't hurt to call around and get more opinions though before I make a trek somewhere.
Your last point is what i'd like to avoid... If a recertification + new valve brings the tank up to the point where I don't ever have to worry about that, all the better for me and the fiance.
Later
C
I think this is one of those cases where calling every propane dealer under the sun is pretty much a waste of time. Just take the tanks in and ask them to recertify them. If they won't, take them to the next place.
I have two 1993 horizontal 30-pound tanks that came with my 5th wheel, no OPD valves. The guy at Suburban here in Grants Pass never even blinked. He said pretty much what Reddog1 said from the beginning - older than '98, no OPD required, recertification gets another 5 years. He recertified them on the spot, filled em up and cut me loose. That was last year. Just had them refilled again the other day at a gas station. They checked the recertification stamp, filled em up and sent me on my way.
