opnspaces
Jun 30, 2014Navigator III
As you found out your new tanks need the new overfill protection device. These tanks are identified by a three lobed handle on the valve.
The Blue Rhino method works if you don't mind the tank only partially filled. But in reality you'll only lose at most $4 for the under fill.
Blue Rhino only works for the 20lb tank. If you need the taller 30 lb tank I've seen them at Costco for $40 which seems like a good deal.
Costco also has a 20lb tank with an actual float gauge for about $30 but you have to pay to fill it after that.
44,056 PostsLatest Activity: May 04, 2014
