fallsrider wrote:
We bought our '95 TT 14 months ago. The seller said he thought both 30 lb. propane tanks were empty. Apparently not, because we just ran out of propane this weekend on the one tank we've been using, and I know there is some in the other tank because I removed it and shook it after we bought the trailer.
All along, I've figured we will eventually need to replace the tanks one at a time as they run out, because they are old and cannot be refilled or converted. 30 lb. tanks are expensive, though.
I contacted my local mobile RV repair guy and asked where is the best place around here to get tanks and get them filled. He said that he converts his trailers (his wife runs a trailer rental business) to regular 20 lb. tanks to make them easy to exchange. He said my cover should work with the smaller 20 lb. tanks.
Has anyone done this, and do you think it is a good idea? We don't run the furnace much because we camp on W/E sites, but we do use the stove, and occasionally heat water on gas. I did get to thinking that there would be less weight to haul around. I just don't want to regret that decision later on if it is better to stay with the 30 lb. tanks.
I wouldn't do this but it's up to you. I would just get them recerted for a few bucks and get on with life. I did my 30 lbs'ers a while back. New valves and the cert cost something like 40 bucks.
