Lwiddis wrote:
I just use one until it’s empty and switch over. Then I remove the empty one, load it in the Tahoe and find a place to fill it. No one uses that much propane. If you smell propane anytime except when filling or removing a tank, get it fixed pronto.
I had the same problem when I bought my latest camper.
Close examination showed the hoses were only half assed screwed into the tanks.
I removed them, put a little plumbers tape on the threads and installed them correctly. No problem... (Cheap fix)
