- opnspacesNavigator IIICheck the vent hole on your propane regulator again. On my trailer I would smell propane from time to time when I walked near the front. But spraying soapy water around all the fittings never produced a bubble. Then one day I dipped a finger in the soapy water and covered the downward facing vent of the regulator and the bubbles started.
As far as leaking through the hoses or leaking because the tank valve is not fully open; I would think that your soapy solution would identify that. - jaycocreekExplorer II
Kayteg1 wrote:
For me any heavy object behind rear axle is no-no.
Why not put front platform? I carry my big Honda on front hitch and not only that solves storage issue, but helps in COG, what my camper has behind the axle.
Not everyone has that problem,Kayteg..Just a plain old ATV cargo carrier will work in the rear for those of us that do not have monster truck campers..LOL..I am preferring something on the Lance bumper though.
In your case,I see why you do it that way.. - Kayteg1Explorer IIFor me any heavy object behind rear axle is no-no.
Why not put front platform? I carry my big Honda on front hitch and not only that solves storage issue, but helps in COG, what my camper has behind the axle. - jaycocreekExplorer IIThe Adventurer 89RBS is probably the only truck camper with a slide I would consider because of the length and weight..We looked at an 89RB when we were traveling and liked the fit and finish..
My point is,the bumper on the 89RBS was huge and it appeared it was large enough for a propane tank holder to carry atleast one extra propane tank making it equal(sorta) to two 7 gallon tanks(Vs 3 five gallon tanks) used on trailers etc..That would make running the generator for the AC way more non problematic..
Like you,when taking my UTV and trailer,bringing extra stuff just isn't an issue but without the trailer,room for stuff is an issue..The only place I saw on the 89RBS to put my Honda 2K in the TC, was in the bathroom because of the slide..
I am considering a small platform on my bumper to carry my generator or an extra propane tank in the wintermonths.. - Boondocking2019Explorer
broark01 wrote:
I have the 2500 Cummings (Onan) LP generator. Found myself in Georgia in a Walmart parking lot one particularly hot/humid evening. Started the generator and turned on AC. By the next morning (about 10 hours later) it had sucked most of a 30 lb tank (7 gal) dry and the generator died because the tanks was so cold that it had frosted up on the outside. Switched over to the other tank, finished breakfast and hit the road. Compared to a gasoline powered (Honda), not a great choice for efficiency or even quietness but it is handier than heck.
If I was really going to boon-dock for an extended period of time, I would load up my Honda EU2000.
As I mentioned earlier I still have my Portable Yamaha 2000 kw Gas Generator. For extended boondocking with my UTV the Portable Generator can be carried in the Cargo Trailer. Another option is a spare Propane Tank to carry in the Cargo Trailer, equals less weight and fuel. - broark01Explorer III have the 2500 Cummings (Onan) LP generator. Found myself in Georgia in a Walmart parking lot one particularly hot/humid evening. Started the generator and turned on AC. By the next morning (about 10 hours later) it had sucked most of a 30 lb tank (7 gal) dry and the generator died because the tanks was so cold that it had frosted up on the outside. Switched over to the other tank, finished breakfast and hit the road. Compared to a gasoline powered (Honda), not a great choice for efficiency or even quietness but it is handier than heck.
If I was really going to boon-dock for an extended period of time, I would load up my Honda EU2000. - billtexExplorer IIPropane is great for keeping carb from gunking up. Problem for me is I need genny when I need heat (ski camping) this made it challenging to carry enough propane so I run genny on gas. 1 tank (1 gal) of gas in H2K will run 10-12 hours. That’s plenty for a ski weekend.
- towproExplorerI have a 3600 onan in my new Motorhome. I run it while driving around for AC (15000 BTU). We will take the rig out out to dinner some times to exercise the engine and generator. I let generator run the whole time we are out, etc. The number that sticks in my head is 1 gallon per hour. Its really about .8 gal per hour but I can remember 16 gallons - 16 hours.
If I was to head to a boondock place I would still drag out my Predator 3500w inverter. Running my last truck camper with 9000btu I would burn around .2 gallons per hour (I can remember 2 gallon tank would last a 10-11 hour night in a hot truck stop)
another thing I never thought about is the cost of propane. if you find a good dealer take care of them. one place charges $2.50 per gallon, but everyone else is from $3.79 - $3.99. that swing is $24.00 different per 16 gallons.
1 gallon propane = 91500 BTU
1 gallon gasoline = 114000 BTU
= gasoline has 25% more BTU per gallon - billyray50Explorer
Joe417 wrote:
Recently took a 2 week trip.
Kept the fridge on gas about 4 days before, 14 days traveling, and 2 days after.
Ran the generator 4 hours one day and 2 hours another day for AC. Also ran it 10 or 15 minutes 4 times for microwave use.
Ran the water heater through a heating cycle I think about 8 times.
Then, on the way home it turned cold and used the furnace 2 nights in about 35 degree temps.
That was on a 20 pound tank and it still has a pound or two in it.
Could also be the tank wasn't filled to capacity when filled.
I weigh my tanks after filling. The 30# tanks weigh 55# when full and one 20# weighs 37# and the other 39#.
I also have one tank with a gauge and find it inaccurate.
Thats pretty darn good usage for only a 20 lb. tank? I personally never got that much usage with a 20lb.and I checked for leaks too. LOl - Joe417ExplorerRecently took a 2 week trip.
