- Jebby14Explorerthanks guys. just to clarify I intend to rip out the wired one in the camper and replace all. I don't mind putting 2 or 3 units as long as im covered for co lp and fire not worth poisoning my family to save a few bucks
- bobndotExplorer IIIThe rv OEM units is also an LP detector. Does the portable one you plan to buy also incl. LP ? The below link explains and offers models to choose from. ( sorry, the models are not from Victoria's Secret )
http://www.trailerlife.com/trailer-how-to/trailer-tech/proper-selection-and-maintenance-of-smoke-and-carbon-monoxide-detectors-are-critical-for-safe-rv-living/ - IAMICHABODExplorer IIIWhat is needed is a dual chamber detector that will detect CO and smoke from a slow smoldering fire such as may start in a R/V because of electrical fires and fast burning smokeless fires.
After a lot of research and talking to Kidde, they assured me that this one would work in a home and also A RV,there is no difference.
This is what I found.
A Kidde KN-COSM-XTR-BA Nighthawk
That seemed to be best suited for this kind of application.
Like This
They now can be bought at Home Depot, also At Amazon.
Home Depot
Amazon
I suggest you read all the info and make your decision on this but I replaced the ones in my Class C with this one.They are rated for 10 years
and most are only rated for 5,If your RV is older than 5 years old and they haven't been changed they are most likely no good. Mine needed to be replaced so this was a good deal for me, I had a hard wired one and I chucked it for the battery powered ones, they can be checked before each trip by pushing the test button in the center of the unit. - ksg5000Explorer III buy my fire/carbon monoxide detectors at Big Box stores. I suggest buying a carbon monoxide detector with digital readout - the other ones are like the idiot lights in a car which always leaves you wondering how serious the problem is. I move our carbon monoxide detector into the stick house when the RV is stored during winter - does double duty. I am unsure whether you can find a propane detector that runs on std double A batteries - be interested to see if others have found one.
