Hey y'all I'm looking at several places on my camper the caulk has split or just left completely. My question is what is the proper caulk to use? Its needing it bad around the rear bumper and other tr...
For adhesive caulk use 3M 4200 on your bumper. It will last forever and even cures under water. Many people use 5200 which has the same properties but cannot be removed. 4200 can be removed with the use of special solvent. But be aware it will rip the wood right off the wall before it lets go. Only to be used where you never want to remove the item you are adhering.
