ognend's avatar
ognend
Proper tire inflation
Hello,
Can someone chime in on this?
The inside of my truck driver door has a sticker that says to inflate the front tires to 55 psi and back tires to 80 psi. That makes sense to me since the weight of a trailer or whatever else in the back will be on the back tires more than anything else. Granted this info relates to the stock tires (in my case 245/something/something) but even you went to different tires - still should apply.
Am I correct when I say this?
I have been battling (well at least in my mind, since I am not a mechanic) service shops and even Discount Tire over this. I bought a set of 4 tires some months ago (Nitto Terra Grapplers) and they are clearly labelled to 80 psi max load, the sticker is there on the door, yet they gave me my truck back with all tires set to 55 psi. My mechanic does the same after tire rotation and balancing.
I actually asked him and he said that "he always puts all tires to the same psi and just ignores the sticker". That doesn't make any sense to me. I can maybe find some logic in it if you only use your truck "for show", drive it around town without any loads in the back.
Am I wrong?
The other question I have is: I have observed the other day when the temps are in the 110 range that the tire I inflated to 80 psi on my trailer was actually at almost 90 psi. This is because of the heat, no? If so, what do you do when you go on trips in the summer? Start the morning at 80 psi and then watch the tire during the day and deflate if it gets over the limit?
Sorry, I know some of this stuff may sound ignorant but I just want to be safe :)
Thanks!
OD
  • Of course the guy at the tire store knows more than the engineer that designed your vehicle. And yes air temps will affect tire PSI. Adjust accordingly.
