path1's avatar
path1
ProPride measurement
I have a stock dodge 2500 2 wheel drive and TT is 29 inches to top of ball. I'm figuring out clearance if I go with PP3.
Does anybody know what the distance is between these lines?
  • Thanks everybody.
    With current set up my tailgate barley clears without hitting. Want to make sure I won't have any problems on top or to close to ground.
    Thank
  • I believe a Hensley is 5 inches from the top of the ball to the top of the stinger opening. I suspect the PP is about the same.
    Barney
  • I can't help you as my TT is in storage and not close by. The reason why I'm replying is why you ask the stinger, the part that connect the TT to TV, is adjustable via bolt holes. So you can adjust up or down as needed.
