Freedom_49's avatar
Freedom_49
Prosine 2K Inverter/Charger Repair or Replacement?
This device is now nine years old and I am getting frequent panel faults. Is it worth buying a new panel (if I can even get one), and if not, what would people recommend to replace it with? The inverter/charger combo has proven to be excellent.
NOTE - any new device would have to have a remote panel, given the location that it will be installed.
  • I replaced 3 of those in my unit's lifetime.. last one was about $250 and available only from Xantrex. That was about 2 years ago. Not easy to get that from them - it took a few calls to tech support..telephone only.
    She died at age 12, but served me well for all those years. I think I burned up the transfer switch running my a/c.
    It was not installed a truck camper.
  • From what I read you will get very little support from Xantrex including that the remote panel is not available separate.
    I quit Xantrex and have gone GoPower along with separate charging and separate transfer switch. I prefer separate components so you are replacing only what fails.
    Good luck.
  • You might just start with the cheap $4 phone cord between the remote and inverter. While that is probably not the cure, it is the lowest cost way to rule that out.
    You can write to this group, and they have lots of experience with Trace inverters and inverter/chargers.
    HomePower.com
    My guess is that a new inverter/charger will be much lower cost than yours was 10 years ago. That will solve the problem for sure.
    Check several locations, including SolarOnSale.com Amazon.com Sunelec.com and your favorite local solar dealership. Internet sales have a lot of competition, and prices are held pretty low as a result.
    I have read some of the history of Trace inverters, the guy who bought several inverter companies creating Xantrax, and the history of Outback Inverters. My next inverter will probably be a Outback inverter. The guy who designed the Trace inverters has been working at Outback coming up with more innovative items, and making military grade inverters that are totally sealed, so that dust would not be a problem anymore!
    Check HomePower.com Magazine for advertizes of this inverter. It will be much more durable than the Trace inverters, like the 1997 version that I have in my motorhome.
    Good luck!
    Fred.
  • RoyB wrote:
    Are you wanting to replace the Prosine 2.0 or just the remote panel...
    Roy Ken
    That's my question really. I am not sure it would be worth replacing the panel; hoping somebody has some experience with that.
  • RoyB's avatar
    RoyB
    Explorer III
    Are you wanting to replace the Prosine 2.0 or just the remote panel... Just did a search on google images and see the remote panel being shown on a few pages...
    Roy Ken
  • Ivylog's avatar
    Ivylog
    Explorer III
    You probably have a telephone cord to your remote. Newer units need a Cat 5 or even six wires limiting your choices. Instead of replacing mine I put in a new separate PSW system to power the home refer I'm putting in.
    Fortunately before buying a used unit I checked on parts availablity for the Prosime and parts are not available from Zantrax.
