time2roll
May 23, 2020Nomad
CapriRacer wrote:I believe my truck with common P tires took 32 psi. My factory options included LT and call for 35 psi on the door sticker. Same size tire.
Totally wrong answer!!
The correct answer is: If the numbers in the size are all the same, in order to carry the same load as a P type tire does, an LT type tire has to use 15 psi more (more or less. Precision isn't necessary here!)
I would go with the load tables to cover GAWR and add 5 psi not to exceed the sidewall max.
