StirCrazy
Jun 08, 2020Moderator
cj_rezz wrote:StirCrazy wrote:
are you using a generic table for your tire PSI/Load , do your self a favor and email the manufacture and ask for the load chart for that tire.
I did this for mine, the values are close but they also can give you little tips that are specific for that tire. for mine they recommended not to run the tire under 50psi as at 45PSI they get inconsistent wear.
Steve
I am just using generic tables at this point. I did email Nokian a couple of days ago but haven't heard anything back yet. Hopefully I will and this will provide some extra information.
ya the numbers will be pretty close, but if I went for the unloaded weight on my tires, i would be running them at about 35 PSI. but the company said not to run them under 45 so I picked 50 for my unloaded rear PSI to give a bit of room. when I am loaded with the 5th wheel I run 75 PSI, got 80000Km out of the last set doing this so must be good. for loaded I set the tires at 5PSI above the PSI for my actual weight on the chart for the rear.
Steve
