Grit_dog
Jun 08, 2020Trailblazer
StirCrazy wrote:
ya the numbers will be pretty close, but if I went for the unloaded weight on my tires, i would be running them at about 35 PSI. but the company said not to run them under 45 so I picked 50 for my unloaded rear PSI to give a bit of room. when I am loaded with the 5th wheel I run 75 PSI, got 80000Km out of the last set doing this so must be good. for loaded I set the tires at 5PSI above the PSI for my actual weight on the chart for the rear.
Steve
All good, but curious what tires and what "company" said 45psi min?
Doesn't make sense. 19.5s need considerably more and I haven't ever seen a LRE tire that was 45psi min.
