cm11599ps wrote:
I've been towing a 26' 8,000# camper with my Ram 1500 for the past 4 years with the stock passenger tires. Door jamb says 39 psi. Tomorrow I am having a set of BFG LT tires put on and was wondering if the psi should remain at 39.
Also, what about when towing? Should I adjust the psi when towing? I've never changed it.
What load range are the new tires C, D, or E? And what is the max side wall inflation?
There are no gravel pits, movers or the like that might have scales?
If you are greatly below the max weight rating of the tire, and run at full pressure you will have less traction for getting going and BRAKING!!
