mikemc53 wrote:
Still haven't settled in on a particular rv or format yet but we really like looking. Stopped in at a dealership today and the salesman showed us a used 5er, a 40 ft Komfort (by Dutchmen) which had a GVWR of 15500. I commented that this wasn't a unit for a 3/4 ton but was told (obviously) that it is doable. Now I know little about this stuff but I am rather sure that at 15500 lb with an approximate pin weight of 3000 lb that the 3/4 ton would not handle this at all. I would like to know, though, what it would take to pull something of this size, comfortably?
I understand that without all of the data it is kind of open-ended but, in general for a 40 ft 15500 lb 5er, what would we be looking at?
No way ANY 3/4 ton could handle that kind of load. You are probably looking at a dually 1-ton.
You need 3000# payload for the pin, 200# for the hitch plus driver, passengers and fuel. A 4000# load is not impossible.
MAYBE, just MAYBE a new SRW 1-ton, but you need a low ratio (15-18%) pin weight and travel light for that to work.
If you want to be SURE you are OK and not have to worry about weights, then a dually is peace of mind.
