ACZL wrote:
Cummins12V98 wrote:
Here is my scale weight from the factory my new 2016 MobileSuites 39TKSB3. It is about 39'-6" long. What is scary is you will see people with a 350/3500 truck pulling this same RV. When we finish loading it up we will be over the 21K for sure and north os 5K pin.
If you're saying it's scary to see 350/3500 trucks towing this due to it's weight, then why didn't MS put 3 axles under it instead of just 2?
I should have said 350/3500 SRW. That's scary!
Not sure what 2 or three axles has to do with it? The GY H tires combined are rated for 19,200#. Anything bigger does come with 3 axles.
This is my new RV that I will be towing with my new RAM 3500 Dually.
