Goldstalker
Mar 06, 2014Explorer
ah64id wrote:ravenfan1 wrote:
It has 5.3 4*4 with 3.42 gears and it say its tow capacity is 7200 pounds
What is the GVWR of the TT?
That has no bearing it could be 12,000lb GVWR just means it has stronger axles. It only matters how much "stuff" you are gonna load into your camper and you just need to be smart about it. If it weighs 5500lbs empty then load about 1000lbs worth of gear and you will be fine.
44,068 PostsLatest Activity: Jun 10, 2026
