- GoldstalkerExplorerYou will be just fine just don't load the bed with a bunch of gear put in all in the trailer as payload will be your only concern.
- loulou57ExplorerWe have a 2012 Avalanche. We pull a 27QBSS, one long slide, actual 31'8". Dry weight 4201 GVWR 5993. We have no issues pulling. We also pull our 20' princecraft boat behind the trailer sometimes. We have a good weight distribution bars Enjoy!
- AH64IDExplorerThe dry weight is probably low, and if you have a 1/2 ton that is a fairly soft suspension for such a long trailer. It would handle fine under normal circumstances, but have an emergency stop or drive on crappy roads and the 1/2 ton isn't enough in IMHO.
- abc40kidsExplorerYour more than ok and a good set of weight distribution bars will help keep everything nice and level.
- hammer21661Explorerif you have the 2500 you are ok. If they still make or made it that year.
- SprinklerManExplorerSince you are from the "Dena" the answer is yes . What you need to do is see what the towing capacity is for the truck . What motor you have , etc . But I dont see you having a problem .
44,050 PostsLatest Activity: Sep 20, 2025
