psears18 wrote:
Yea that's 7500# dry weight and I do have the tow package
Way too heavy for the F150. I towed a loaded 7300lb TT with my 2010 F150 5.4 MaxTow. Hated it. The worst part was the lousy 6sp tranny. No way to lock out OD. The tranny wants to hunt for gears most the time. IMO it's part tranny, part underpowered 5.4. The 5.4 doesn't have enough power to hold a gear with that weight. MPG's are around 8.5-9, which is on the low end for gassers. With 7500lbs dry you most likely will be 8500lbs loaded. That's 1000lbs+ on the receiver. Add in passengers and what ever else and you'll be close to the RAWR.
I would look for a TT in the 5000lb dry range.
