dojojones's avatar
dojojones
pulling trailers over 35 feet.
I have a 24 foot camper. We are thinking of upgrade to a 37 foot camper. I have a 3/4 ton dodge (gas). This is probably a stupid question but is my truck big enough to pull one? and 2. Are these big trailers used for regular travel camping or do people usually get permanent sites for them?
  • you can pull with a gas truck...
    lots of people pull large trailers for just vacations
    and, lots of people keep them at one site.
    How big is your Dodge engine? What areas i.e. states, mountain ranges etc etc will you be generally towing in. Recommend you install an exhaust brake if they make one for your engine. 37' to 40' trailers are in the longest group of trailers, with 32' to 34' pretty average, then the next group is 22' to 30". A 37' is fine for RVing other than just having a permanent site BUT generally, you will find yourself at the larger RV parks. In calif. you probably not fit in any of the forest service or state parks. Buy a good trailer hitch not a cheaper one. Make sure you have some good side mirrors, not the cheap kind that wobble and are hard to see with. Recommend installing a CB radio for the truck and a hand held CB for your spotter to help you in backing your rig into your RV site. I prefer a 5th wheel over a tow trailer. They tow better and are easier to back up with. Suggest you have 10 ply "G" rated tires for both your truck and trailer. I like the Good Year LT G640 "G" rated tires. You might want to look at the size of systems for both your tranny and cooling system, up grade if possible.
  • WE have had Jayco travel trailers over 35' and presently one that is 40' We use a 3/4 ton truck Dmax diesel and have pulled for over 90,000 miles. We don't even know the trailer is there. Standard Reese hitch with anti sway bar.
    The biggest hurdle is finding a good fueling station or just going to a truck stop. Secondly is to make sure that the RV park is cool with large trailers. Call them up to find out if their idea of a site is what you want.
  • I'm working on a deal now to get myself a 35' TT.
    And when I get it I will be towing it everywhere I would ever pull my 27' And it will be off road, on narrow logging roads and into lakes in the mountains and anywhere else I want to go like I do with every TT I have had.
    Only difference will be a little extra caution pulling it through these areas. Might have to put some heavy duty skid castors on it though...
  • I use mine 2-3 weekends a month, 100% boon docking, most of it on dirt trails. It's nearly 40' and has 4 slide outs.
