Thom02099
Nov 12, 2020Explorer II
dcrawdad29 wrote:
Hi, I have an 08 (low miles) Tahoe, 3.73 rear axle, 5.3 L, V-8, 4-speed, tow capacity just over 7k, tow/haul mode, pulling a hybrid TT of dry weight 4,000 lbs with electric brakes, using weight distribution hitch and sway bar. Installing OEM trans cooler before the trip next June. Traveling from St. Louis, itinerary may be Rocky Mountain National Park (camping near Estes Park), then onto Glenwood Springs, then backtrack to Colorado Springs (probably through Denver), and finishing up at Sand Dunes Natl Park. I am asking for advice on roads to take/avoid and thoughts on how well my vehicle will do. I am most concerned about I70 West and then back again going through Vail Pass and Eisenhower Tunnel and should I stop short of that, drop the camper at a campsight, and go through Vail Pass onto Glenwood Springs without the camper? Any recs on campsights around that area if I camp before Vail Pass? Any other thoughts on other roads I may have difficulty on with my other locations?
I can give you some insight into pretty much the same tow vehicle (I have a 2003 Tahoe LT,same engine, rear, etc now retired from towing) and had a 2007 Outback 25RSS, ~4900lbs fully loaded for camping, with WD hitch. The Tahoe can handle that weight but as others pointed out, it will at times be slow going. 45MPH up the approaches to the Eisenhower/Johnson Tunnels? Not a chance. Best I could do on either approach was 25MPH in 2nd gear, in line with the semis with my flashers on.
You mentioned going to RMNP and Estes Park. Three different ways from the east to get up there -- US 34 through the Big Thompson Canyon, US 36 through Lyons and Pinewood Springs, and CO 7 through the South St. Vrain Canyon. I've been up the Big Thompson many times with the Tahoe/Outback combo and it's certainly doable. Some very slow going in the Narrows, and a steep,twisty section (10-12% grade) outside of Drake, where you'll be doing about 20MPH with that combo. Fortunately, there are a lot of slow vehicle pull offs for you to let traffic go around.
CO7 up the South St Vrain, to me, seems to be much steeper for longer periods of time, with fewer slow vehicle pull offs. Also a goodly climb up from the CO7/CO72 junction to Allenspark and Meeker Park. Pretty steep descent in to Estes Park, but gearing down to 2nd makes it manageable.
US 36 is a good way to get up to Estes Park. Not quite as "canyony" as the other 2, some fairly steep climbs up outside of Lyons up to Pinewood Springs, but with some climb lanes.
If you're planning to stay inside Rocky, at either Moraine Park or Glacier Basin, be aware that, for the 2020 season, due to Covid there were restrictions on which loops were open and available. Glacier Basin has 4 loops, 2 of which were closed (just my luck, all of my reservations were in the closed ones). I would fully expect that, if the coronavirus is still as virulent in spring 2021 as it was this season, you'll likely see the same thing. Make sure to get reservations at the earliest possible date within the 180-day window.
If you're staying in a commercial park in Estes, be aware that the rates were up a bit at some of the RV Parks. Again, get reservations early if you can. The least expensive park is the Estes Park Campground at Mary's Lake, which is up in the $47-$51/night range now.
ETA: Just recently checked Mary's Lake website, they are now up in the $50-60 range, depending on W/E or FHU sites.
