tls5150
Sep 09, 2019Explorer
Pulling with 1/2 ton
Looking for feedback on trying to pull a rockwood ultra lite 26’ with a 2014 z71 Ltd 4wd, with 3:42 rear end. Dry weight of the trailer is 6300lbs. Any advice?
TurnThePage wrote:So you are fine and it does show how easy it is to go over the trailer GVWR.time2roll wrote:I'll have to be approximate.TurnThePage wrote:What is your trailer dry weight, actual weight and GVWR?
In reference specifically to half ton towing, why do people say, "use the max trailer weight?"
Some trailers have 3000 lbs of cargo capacity (Who's going to use all that?!). Some have under a 1000.
Even with excessive amounts of tools, backup parts, winter supplies, summer supplies, extra battery, solar panels, various added accessories, food, 50 gallons of water, grill, camp stove, camp table, camp chairs, cast iron pots and pans, and assorted other sundries, I can't seem to get over about 1500 lbs of stuff in my trailer.
What is your towing capacity?
Dry weight: 4800 lbs
Actual weight: 6100 last time weighed, as high as 6500 lbs
Trlr GVWR: 6000 lbs
Ram half ton towing capacity: 10,600 lbs
