tls5150
Sep 09, 2019Explorer
Pulling with 1/2 ton
Looking for feedback on trying to pull a rockwood ultra lite 26’ with a 2014 z71 Ltd 4wd, with 3:42 rear end. Dry weight of the trailer is 6300lbs. Any advice?
JIMNLIN wrote:
One half ton truck have more different GVWR and RAWR than any truck on the road. So when someone jumps up and says a 1/2 ton truck should stick with a 6k trailer I say bull dust. Need to stop watching you tubes/reading magazine specs and read the truck makers body builders weight specs and tow ratings on their respective websites for actual numbers specific to their model trucks options and std equipment.
Or they bit into the 2800-3200 lb gvwr based payload debacle. Choose the right F150 gvwr/rawr packages for towing those 10k trailers.
