tls5150
Sep 10, 2019Explorer
Pulling with 1/2 ton
Looking for feedback on trying to pull a rockwood ultra lite 26’ with a 2014 z71 Ltd 4wd, with 3:42 rear end. Dry weight of the trailer is 6300lbs. Any advice?
TurnThePage wrote:
In reference specifically to half ton towing, why do people say, "use the max trailer weight?"
Some trailers have 3000 lbs of cargo capacity (Who's going to use all that?!). Some have under a 1000.
Even with excessive amounts of tools, backup parts, winter supplies, summer supplies, extra battery, solar panels, various added accessories, food, 50 gallons of water, grill, camp stove, camp table, camp chairs, cast iron pots and pans, and assorted other sundries, I can't seem to get over about 1500 lbs of stuff in my trailer.
tls5150 wrote:
Thank you all for the responses!! My 1/2 ton is rated to pull 9,400. Was considering the new 1/2 Silverado with max tow package rated at 11,300. It is just DW and I nothing unusual as far as packing except two bicycles just struggling on what to do
Desert Captain wrote:
So what is "odd"? :h
We both had rigs that towed well at or near our payload limits. What was your alleged towing capacity? I'm guessing Ford told you it was 9K# or more but we both know better.
:C
GMC Sierra 1/2 ton 6.2L with Max Tow Pkg. 28 ft. TT loaded for a cross country trip out west...weighed in 7000 Lbs +/-. No problem pulling or braking. If truck is maintained to near spec level and you know it’s limitations, the set up and pulling of a properly loaded rig will allow you to travel safely.
am1958 wrote:Desert Captain wrote:
My SCab F-150 was rated for 8,600 max tow but my 5,600# 22' TT was alll that it could handle - it towed well but I was near or even at my max payload almost every trip.
:C
Odd... My SCrew F-150 EcoBoost has towed a 6500lb dry/7500 loaded Bullet Premiere 31BHPR, (31'), with a measured tongue weight of 940 putting me pretty much at the limit of the advertised payload just over 17000 miles in the last 4.5 years without incident. I've taken it through the Blue Ridge Mountains a few times and have no problem on the hills and sometimes, when windy - high wind warning to be accurate, the F-150 sway control kicks in which is a very benign incident where I usually just re-engage cruise and carry on.
